Baarssen
Posts posted by Baarssen
I do support your post. However i dont have a Thirtybees shop live at this moment i believe in this project so i did my contribution to it. Come on guys, if everybody only makes a small donation its done and we all will have the profit of it.
As Vincent says, if you cant give much, just give a small donation of 5 or 10 dollar. It should also be a big motivation for the project owners to see how many people supports them. I think they will be more happy with 100 donations of 5 dollar then 1 of 500
I can confirm these mails cannot be edited(only the new order message) in the backoffice. Maybe something to make a pull request so it is fixed in a next update
Maybe an idea, ofcourse it doesnt solve this with the module, but i use since very long time https://www.easycron.com Works fine, and without any problems. Its free, but if you want to have some more functions it costs a few dollars a year. You get notified if a cronjob fails, also when it resumes.
here it is, however i guess its mandatory you will have terms which has to be confirmed by your customer.
dont know if someone mentioned it to you @CoffeeGuy , but a lot of information can also be found at https://docs.thirtybees.com/
thks that worked. For cms that can be done too i guess?
Yes thats fine, if i can manage it in an easy way
(TB 1.04) Unfortunately there is no possibility to set columns in the advanced settings of my theme(or default theme) for the following pages:
- product -category -cms
Especially in my case for the product page this is important. I earlier asked this, but i couldnt manage to fix this. I hoped this was fixed in this version(1.04)
I can confirm the visual composer module is a disaster. It has cost me also loads of time to get my shop back after installing it. The only comment you get if you ask for help; we have 1000 satisfied customers (so your complaints are fake). Thanks for the link @SnowyCat i will also try thatone.
In my experience people often make mistakes with adding the password when logging in. I use hotjar to follow in this case what the customer is doing(ofcourse i cant see the credentials) and then try the password. Almost always the mistake is done with the password.
In this case the best is to do like @Manisch and just add manual a new password. Just not to offend your customer.
what i do in this case i make all the attributes global for this product and after creating the combinations i delete the combinations who are not possible. In that case the visitor will get a notification when they choose a combination which is not possible. Its not the most perfect solution, but i do not use very much specific product attributes. For me it works this way, maybe for you its not the right solution.
Maybe someone else can give an idea.
@Manisch site looks good, i agree some more content will help. But if the products are getting lost in content its also not helpfull. I watched the other site chewy.com but i should leave it because it gives so much info i cant find the products i am looking for. Maybe something to look at are the prices. Maybe too low? I am selling products since 2005 on internet and i discovered that sometimes, especially when its a private label product it is not helpfull to be cheap. I raised for my private label products the prices with about 30% and my revenue almost tripled after that.
Just curious: which theme did you use?
Zou een mooie opdracht zijn voor zon data specialist om dat uit te zoeken hoe dat makkelijker kan. Maar het zal alsnog veel werk geven. Een vriend van mij is eigenaar van een hele grote shop waar zon 50.000 producten verkrijgbaar zijn en deze staan ook allemaal in hun online shop. Alleen al op de afdeling productmanagement werken full time 5 mensen om dit vlekkeloos te synchroniseren. Zolang je leverancier niet is ingesteld op dropshipping zal je een hele klus houden dit naadloos aan te sluiten op je shop. Maar ik heb geleerd dat niets onmogelijk is :)
Ik gebruik zelf eigenlijk nooit een csv bestand om producten in te laden (ik heb ook nauwelijks wijzigende producten) maar met een professionele module zou dit toch prima moeten kunnen? Het kan natuurlijk wel zijn dat het csv bestand van de leverancier wat aangepast moet worden want het zou wel mega toevallig zijn dat die in 1 x aansluit bij de tb/ps import. In het verleden heb ik me er wel eens in verdiept en kwam toen telkens uit op de software van prestashopmanager. Of dat in werkelijkheid heel veel verschil met de mogelijkheden van de datakick module of het script van musicmaster is weet ik eigenlijk niet, maar ik vermoed dat je met deze laatste 2 mannen dit absoluut voor elkaar moet kunnen krijgen. Of heb ik het mis?
I think there are more people who are taking some rest at the moment. There are people who normally are very active but now they are not. In an online community we see this very often. However i understand your concerns. Maybe its an idea that some people from the community can support with Public Relations. Something like the ambassador programm like PS. I surely will help with this so if interested i can make some time free for this.
I think we are putting to much pressure at the shoulders of @lesley and @mdekker Also i think TB will have to stop (or at least minimize) with free modules. Life isnt free, so there has to be generated income.
sometimes it takes 10 to 20 minutes before a key is working
I do see it on your site ifrom the first post
er zijn verschillende hostingpartners wat je kan doen is een vps. Dat is uiteraard wel wat duurder, maar je haalt het er direkt uit. Bij Argeweb kun je bv nu een proefmaand nemen voor maar 1 euro, met bv plesk als admin paneel zit je dan voor de eerste maand op 6 euro. Daarna op een 30 euro per maand. Dat werkt prima. Als je dat te ingewikkeld vindt, kan je naar een hosting service overstappen. A2 is geschikt, zoals in het filmpje. Wallgrind.nl kun je ook doen die is voor zover ik het weet voordelig en kan je klein starten en uitbreiden naar groter. Daar kan je ook met installatron je webshop in 1 click opzetten. (gaat eigenlijk allemaal automatisch).
Kort gezegd komt het hier op neer: Heb je ervaring dan is een VPS of een dedicated server het beste(de laatste is ook het duurst). Heb je geen ervaring, of wil je de zorg er niet van hebben kies dan voor geschikte hosting(wallgrind.nl adeko.nl spango.com dewebsmid.nl) zomaar een greep uit bedrijven die zich op dit soort webshops hebben gericht.
Als ik me niet vergis heb je op het prestashop forum ook een post neergezet over installeren. Hieruit begrijp ik dat je bij strato een hostingpakket hebt lopen. Ben ik hier correct in?
Als ik eerlijk ben dan is strato niet de beste keuze om een webshop te hosten. Ik vermoed dan ook dat je tegen de lage performance en configuratie van je webhosting pakket aanloopt.
Een webshop heeft gewoon meer power nodig, en de juiste configuratie, een standaard hostingpakket geeft vrijwel altijd direkt, en anders na een paar weken problemen.
Corrigeer me maar als ik er naast zit
that doesnt solve it for me. For my own theme there are much more tables missing, and the 27-product, 28-category, and 29-cms for my theme(id 2) doesnt even show up in tb_meta. So i give up this, it costs me too much energy. I tried PS 1.7 and everything is there from scratch. I am struggling for months to get things working, dont think this is something for me, i have to spend time in selling, not in coding. I am a bit dissapointed because i see this problem is already mentioned 5 months ago.
Is there already a fix for this problem? I tried to fix it mysef but i am not that familiar with database tables and rowes
i only use mailchimp. Easy and nice newsletters. Under 2000 contacts its free, above it you pay a little. Its connected to my shop, i cam add products easily into the newsletters. I have tried several modules but i stick to mailchimp :)
the marked modules or pages are not indexed, so just look which you want to tick(and so not to be indexed). Its that easy.
invalid mail name .newsletter_conf every time trying to remove powered by prestashop and save in translations
in English
ooh yes @DRMasterChief you are very right. Its indeed also in Prestashop. Well i dont have problems with the footer in those emails because i only frequently use the new order mail, and thatone is only send to me :) So its ok the way it is for me.
