Problem with gzip compression
  • Hi from Poland
    I’m new in this forum. I run shop with ThirtyBees 1.0.3 cms and Warehouse theme from IqitCommerce on VPS - koraledrewniane.pl
    Everything works great for me until i started my site seo optimization.
    All my CCC settings are turned on. The problem is when i run page analysis on gtmetrics.com. Google Speed score says to enable gzip compression on two files:
    http://koraledrewniane.pl/themes/warehouse/cache/v_57_e9e488e51b540995632eae9d70d0811b_all.css
    http://koraledrewniane.pl/themes/warehouse/cache/v_41_b77e132c440c69afc28f0a38b7a71ef1.js
    I have mod_deflate enabled on server.
    What can be wrong?
  • your nginx (reverse proxy?) server is probably not configured correctly. You can read more about this here.
    Note: If you use nginx in front of apache server then you don’t need to have mod_deflate enabled on apache at all. That will have negative impact on overall performance. Let nginx gzip this instead.
  • Thanks @datakick for the answear. I’ll read about that.
  • @datakick this is content of my nginx.conf file:
    #user nginx;
    worker_processes auto;
    pid /var/run/nginx.pid;
    #error_log logs/error.log;
    #error_log logs/error.log notice;
    #error_log logs/error.log info;
    events {
    include /etc/nginx/nginx-events.conf;
    http {
    include /etc/nginx/mime.types;
    # For user configurations not maintained by DirectAdmin. Empty by default.
    include /etc/nginx/nginx-includes.conf;
    and my nginx-gzip.conf file:
    gzip on;
    gzip_static always;
    gzip_disable “msie6”;
    gzip_http_version 1.1;
    gzip_vary on;
    gzip_comp_level 8;
    gzip_proxied any;
    gzip_types text/plain text/css application/json application/x-javascript text/xml application/xml application/xml+rss text/javascript application/javascript text/x-js image/svg+xml;
    gzip_buffers 16 8k;
    gzip_min_lenght 256;
    Everything seems to be ok.
  • try to set gzip_http_version 1.0, or alternatively gzip_http_version 1.0 - this could help, according to this article
  • Setting gzip_http_version 1.0 doesn’t change anything, still the same problem.
  • I’ve just tried your configuration on my test server and it works just fine.
    Well, what strange is that there’s a typo in gzip_min_lenght that needed to be fixed first, otherwise nginx failed to restart. How come your server managed to restart with this typo in config file? Is the nginx-gzip.conf file actually included ? And did you actually restart nginx to reload settings?
  • Yes, there was a mistake. I had changed it to gzip_min_length and of course restarted nginx. Gtmetrix still show the same problem with compression.
  • No, DirectAdmin, but i also have access by SSH.
  • The problem is solved.
    I forced my server administrator to resolve it. He removed this lines from .htaccess:
    <IfModule mod_deflate.c>
    	<IfModule mod_filter.c>
    		AddOutputFilterByType DEFLATE text/html text/css text/javascript application/javascript application/x-javascript font/ttf application/x-font-ttf font/otf application/x-font-otf font/opentype
    	</IfModule>
    </IfModule>
    and add this:
        # compress html, css, javascript, text, xml and fonts
        AddOutputFilterByType DEFLATE application/javascript
        AddOutputFilterByType DEFLATE application/rss+xml
        AddOutputFilterByType DEFLATE application/x-font
        AddOutputFilterByType DEFLATE application/x-font-opentype
        AddOutputFilterByType DEFLATE application/x-font-otf
        AddOutputFilterByType DEFLATE application/x-font-truetype
        AddOutputFilterByType DEFLATE application/x-font-ttf
        AddOutputFilterByType DEFLATE application/x-javascript
        AddOutputFilterByType DEFLATE application/xhtml+xml
        AddOutputFilterByType DEFLATE application/xml
        AddOutputFilterByType DEFLATE font/opentype
        AddOutputFilterByType DEFLATE font/otf
        AddOutputFilterByType DEFLATE font/ttf
        AddOutputFilterByType DEFLATE image/svg+xml
        AddOutputFilterByType DEFLATE image/x-icon
        AddOutputFilterByType DEFLATE text/css
        AddOutputFilterByType DEFLATE text/javascript
        AddOutputFilterByType DEFLATE text/plain
        AddOutputFilterByType DEFLATE text/xml
        # you can also compress by file type/extension:
        <files *.html>
            SetOutputFilter DEFLATE
        </files>
    </IfModule>
    I dont’t know why but it works.
  • Thank you for the information.
  • Mh, that is good news but I also would be interested in an explanation. Perhaps you could ask the admin while also saying thank you to him 🙂
  • It has to do with using older Apache versions. The older versions will not take multiple arguments like the new does.
  • Thank you Lesley.
