Changes and bugs between TB and PS
  • Hello.
    I have readed that TB has repaired more than 2.000 bugs of Prestashop. Is possible to know them?
    For example: For the advanced stock management system, ps has a lot of bugs:
    • Activate the advanced stock management system. (ASMS)
    • Create an order of a product that is controlled by the ASMS and select pay with bank transfer method.
    • Cancel it in the backoffice.
      RESULT: The quantities reserved by the ASMS when the order is created are not turned back to the warehouse when you cancel the order. For example if finally the customer doesn’t want the products.
    This is a simple example. For this reason, I would appreciate a lot if we can know wich bugs have been repaired.
    Thank you very much!!
Log in to reply
