Welcome, Guest!
By registering with us, you'll be able to discuss, share and private message with other members of our community.
Theo
Please help: ThirtyBees 1.1.0: JqZoom Error: Uncaught TypeError: $(...).zoom is not a function
Hi
On a fresh install of ThirtyBees 1.1.0, using any "built-in" theme: Naira, Community:
Enabling JqZoom for product image is throwing an "Uncaught TypeError: $(...).zoom is not a function" error.
Notes:
  • The option to enable JqZoom has been available since the earliest version of 30Bz.
  • This was working for me on 1.08 previously using Community
  • The toggle to enable JqZoom is still in 1.1.0
  • The JqZoom code is still in product.js of the Community theme
  • Also, it seems that both the jqzoom.js and .css files for JqZoom are being loaded (if I do view source)
Please help with a fix if possible. Also, it would be great if we could continue to have this feature available in future versions of ThirtyBees.
Error detail:
product.js:194 Uncaught TypeError: $(...).zoom is not a function
    at initZoom (product.js:194)
    at displayImage (product.js:251)
    at HTMLAnchorElement.<anonymous> (product.js:290)
    at HTMLDocument.dispatch (jquery-1.11.0.min.js:3)
    at HTMLDocument.r.handle (jquery-1.11.0.min.js:3)
Thanks in advance
Update below
* Update:
So I've managed to get this "working" by replacing the contents of the 1.1.0 zoom file: "js\jquery\plugins\jqzoom\jquery.jqzoom.js" with the contents of a file that was loaded previously:
"modules\ctconfiguration\views\js\vendor\jquery.zoom.min.js". And as if by magic, the error disappears and the zoom functionality works again. However, I suspect that this "fix" is grossly incorrect...
It seems that "plugins\jqzoom\jquery.jqzoom.js" was also included in 1.08 previously and that "vendor\jquery.zoom.min.js" was loaded in 1.08 but not in 1.1.0 anymore.
Somehow by calling "vendor\jquery.zoom.min.js", the zoom functionally works... but if it's left out, it doesn't work - even if "plugins\jqzoom\jquery.jqzoom.js" is loaded...
An explanation and fix for this would be greatly appreciated...
Edited by Theo
Share this post
Link to post
7 answers to this question
  • 1
just to do it fast, you can change the old content of  "/js/jquery/plugins/jqzoom/jquery.jqzoom.js" by this one here :
https://raw.githubusercontent.com/jackmoore/zoom/master/jquery.zoom.min.js
infos here : https://raw.githubusercontent.com/jackmoore/zoom/
no need of the css file anymore in the jqzoom directory..
it works instantly 🙂
Later I'll try to dig into that on github and fix that properly.
Share this post
Link to post
Great, thank you. I've updated the file with the latest version of the min file from Jack Moore's Github (although the previous one included in 1.08 also seems to work fine)
So this was a bug then? And I was on the right track by replacing the content of "/js/jquery/plugins/jqzoom/jquery.jqzoom.js" with the "jquery.zoom.min.js" file?
Edited by Theo
Share this post
Link to post
You were on the right track of course.. There is an immense job to be done to update all the Jquery librairies and plugins.... some files are more than 12 years old ^^ 😞
Share this post
Link to post
Thanks Zen. You mentioned that you'll see if you can implement the fix in Github?
Share this post
Link to post
I looked into this issue and there is a simple workaround. Go to your modules and reset Community Theme Configuration module.
One of this module responsibilities is to replace this particular jquery plugin with a new version. It uses displayFooterProduct hook to achieve this. Unfortunately, this hook is not specified in community-theme or niara's config.xml file --> this is what should be fixed
Share this post
Link to post
Hi Datakick
Thanks for this, however, this module wasn't enabled in my modules list, so resetting wasn't necessary... But I have enabled it.
Also, it's not apparent that this module does anything "special" like do magical jQuery library stuff - as its function seems to be only to display the copyright in the footer?
Unless I missed something and selected the wrong module by mistake somehow?
If this module is for something greater, should it not be noted in the module and be enabled by default, regardless of theme?
Edited by Theo
Share this post
Link to post
