alwayspaws Posted August 30, 2017 Author Share Posted August 30, 2017 OK but can you please look at my footer? Please? :) https://www.alwayspaws.com/ Note: Some of the text at the top is not going to be there much longer. Link to comment Share on other sites More sharing options...
wakabayashi Posted August 30, 2017 Share Posted August 30, 2017 Maybe under the help section? Link to comment Share on other sites More sharing options...
alwayspaws Posted August 30, 2017 Author Share Posted August 30, 2017 In other words you mean under the TOS link? I'll try that now with my test site. Thank you, @wakabayashi Link to comment Share on other sites More sharing options...
wakabayashi Posted August 30, 2017 Share Posted August 30, 2017 Yes. I thought so, but no idea how it looks like :) Link to comment Share on other sites More sharing options...
alwayspaws Posted August 30, 2017 Author Share Posted August 30, 2017 @wakabayashi I'll try it and give screenshots. Link to comment Share on other sites More sharing options...
alwayspaws Posted August 30, 2017 Author Share Posted August 30, 2017 @wakabayashi - how do I find "Terms and Conditions - TOS" in my footer.tpl? I have the trust seal working but it's in the wrong place. I know where the CMS is for the TOS. Link to comment Share on other sites More sharing options...
wakabayashi Posted August 30, 2017 Share Posted August 30, 2017 Maybe this is a module. Do you have a module installed, which is named like "footer links" or something like this? Link to comment Share on other sites More sharing options...
alwayspaws Posted August 30, 2017 Author Share Posted August 30, 2017 Thanks, everyone, for the help. I found a good location for the seal using the Transformer theme custom content block and reverted the header.tpl back to what it was before. I had not edited the footer.tpl yet, so it's the same. Link to comment Share on other sites More sharing options...
wakabayashi Posted August 30, 2017 Share Posted August 30, 2017 If the update overrides this files. Yeah then you will have to re do it. I have no idea, why this hover is working so badly. Strangely i can see a z-index=0 :S but you can't change this :( Another fix is needed. Link to comment Share on other sites More sharing options...
alwayspaws Posted August 30, 2017 Author Share Posted August 30, 2017 I'll have a backup of these files. I don't like that hover over my seal, if that's what you mean. I also don't know what this is: z-index=0. Is that on my site? Link to comment Share on other sites More sharing options...
wakabayashi Posted August 30, 2017 Share Posted August 30, 2017 Oh I am dumb. You can fix it. Add this to your global.css div#tl_popupCL1 { z-index: 100!important; } Yes always make backups. When I change files. I always start with comments like: // Changes Alwayspaws ... That way you will find your fixes very fast in your files... Link to comment Share on other sites More sharing options...
alwayspaws Posted August 30, 2017 Author Share Posted August 30, 2017 @wakabayashi (remove that part about "dumb") :) I'll do this right now! And I wanted to ask how to add comments. Now I know. Thank you so much! Link to comment Share on other sites More sharing options...
wakabayashi Posted August 30, 2017 Share Posted August 30, 2017 Oh you need to use different comment styles... ``` // one line comment in php /* multline comment in css and php */ {* multine comment in smarty (tpl-files) *} ``` You will find a lot of examples in google :) Link to comment Share on other sites More sharing options...
alwayspaws Posted August 30, 2017 Author Share Posted August 30, 2017 @wakabayashi wow! I'm learning too much at once today! LOL! Hopefully this is where the ONLY global.css file is: /public_html/themes/transformer/css Your code fixed the problem of the trust seal info being transparent when moused over. Thanks @wakabayashi - blessings to you! Link to comment Share on other sites More sharing options...
ssimard Posted August 31, 2017 Share Posted August 31, 2017 Hey good morning everyone, glad to see this got fixed while I was sleeping :smile: I think it's looking great ! Link to comment Share on other sites More sharing options...
alwayspaws Posted August 31, 2017 Author Share Posted August 31, 2017 @ssimard said in Where to add html before end of head & body tags for individual pages?: Hey good morning everyone, glad to see this got fixed while I was sleeping :smile: I think it's looking great! Thank you! Link to comment Share on other sites More sharing options...
