I have readed that TB has repaired more than 2.000 bugs of Prestashop. Is possible to know them?
  • Hello.
    For example: For the advanced stock management system, ps has a lot of bugs:
    Activate the advanced stock management system. (ASMS)
    Create an order of a product that is controlled by the ASMS and select pay with bank transfer method.
    Cancel it in the backoffice.
    RESULT: The quantities reserved by the ASMS when the order is created are not turned back to the warehouse when you cancel the order. For example if finally the customer doesn’t want the products.
    This is a simple example. For this reason, I would appreciate a lot if we can know wich bugs have been repaired.
    Thank you very much!!
  • Yeah, there are a lot of bugs in asm. I have recognized this bug too. There are more bugs in asm unfortunately. It had good intentions but didn’t quite get to goal.
    I think one of the upcoming projects are asm so I think you can participate and report all bugs and hopefully they will be corrected.
