Problem with stripe webhook
  • Hi,
    I got this message (see message below) from Stripe regarding problem with webhook indicating trouble delivering data to a webhook endpoint - and suggesting it is a server issue.
    My server - cloudways - suggested disabling Varnish cache.
    Is that the correct solution?
    Anyone can explain and help solve the issue?
    Thanks
    Mesage from Stripe payment:
    “We’re contacting you because we’ve had some trouble delivering data to a webhook endpoint associated with your violinparts.net account in live mode …”
    One recent call to your endpoint returned an HTTP status code 500, which signals a server error on your end. You may want to check your system logs to get more information about the error …"
  • administrators
    What does your server error log say?
Log in to reply
