Need help for NETBEANS+TB dev. environment deployment
  • Folks!
    I need to make new module, it is russian-specific, related to delivery integrator’s service.
    I’d like to try to do it by myself. But i don’t know how to deploy the dev. environment in the netbeans IDE (i chose it because it free).
    Kindly asking for any help in this way.
  • I need to integrate our local Russian delivery service into PS/TB. There is payed module for this service, and probably i’ll buy it, but it has not all features, and seems it’s developer does not working on it anymore. Also there’s another great delivery service, yandex.delivery, which also has no integration into TB/PS
  • I need something more, than a text editor. I need tool for debugging also. Is the VS code suitable if i’ll install it on windows environment along with windows versions of nginx, php and mysql? Should i install some extra software, like a node.js?
  • I tried to use codelobster + xdebug with no success. That’s why i’thought to chose feature-rich ide such as netbeans… Anyway, thank you for help, i’ll try Visual Studio Code
