Loyalty points in products view
  • I’ve noticed on the stock theme that you say what the product is worth in loyalty points, in the products view, that’s great. However, when you change the quantity or change an option that changes the price, the loyalty points display doesn’t change accordingly.
  • Template caching might be too strong with this module. I think I’ve seen it before. We can verify by clearing the cache. After you clear the cache on the page “Advanced Parameters > Performance”, does it get updated?
  • Solved via module update
