Elasticsearch Cli raw installation
Any help to complete this elasticsearch cli raw installation will be aprreciate.
A - ELASTICSEARCH SERVER
$ yum install java-1.8.0-openjdk -y
$ curl -L -O https://artifacts.elastic.co/downloads/elasticsearch/elasticsearch-5.4.0.rpm
$ rpm -i elasticsearch-5.4.0.rpm
$ vim /etc/elasticsearch/elasticsearch.yml
  network.host: 0.0.0.0
$ systemctl daemon-reload
$ systemctl enable elasticsearch.service
$ systemctl start elasticsearch.service
$ curl localhost:9200
B - TB SERVER
- Apache/2.4.6
- PHP 7.1.26
- Download and install the TB-elasticsearch module at https://store.thirtybees.com/shop-modules/front-office/elastic-search-module
- But the module is not up to date so you need make the changes describe at https://github.com/thirtybees/elasticsearch/compare/1.0.0...master in the followings files:
          - elasticsearch.php
          - views/templates/hook/vue/main-search.html.tpl
          - views/templates/hook/vue/results.html.tpl
          - views/templates/themes/panda/hook/vue/main-search.html.tpl
          - views/templates/themes/transformer/hook/vue/main-search.html.tpl
          - views/templates/themes/warehouse/hook/vue/main-search.html.tpl
          - views/templates/themes/warehouse/hook/vue/results.html.tpl
- To solve "Amount of items indexed" not counting up inserted the following code after line #377
          if ($product->active ==='1')
          {  $product->active = true; }
          else
          {  $product->active = false;}
- If you want use php 7.2 you need made change at modules/elasticsearch/elasticsearch.php:
1191 # $xscheme = '([a-zA-Z][a-zA-Z\d+-.]*)';
       $xscheme = '([a-zA-Z][a-zA-Z\d+\-.]*)';
1199 # $xhostName = '([a-zA-Z\d-.%]+)';
       $xhostName = '([a-zA-Z\d\-.%]+)';
C - TB BACKOFFICE
BO / Modules and Services / Positions /displayTop / Top
BO / Modules and Services / Modules List / Block Layered Navigation / Configure / Disable
BO / Modules and Services / Modules List / Block Search / Configure / Disable
Edited by pessoal2004
3 answers to this question
You can find that issues mentioned on github.
There's a couple of notes on elasticsearch:
1. In the 6.x branch of ES there is a weird limitation for some fieldtypes, that why dome products cannot be indexed. I opened issue on github about that, but still no answer.
2. It is obviuos, that native TB's (or Prestashop's) search engine can fulfil 90% of customer needs (if not 99) and ES required for shops with huge SKU amounts, that's why there's no much progress in this module development.
1. In the 6.x branch of ES there'a a weird limitation about some fieldtypes, that why some products cannot be indexed. I opened issue on github about that, but still no answer.
2. It is obviuos, that native TB's (or Prestashop's) search engine can fulfil 90% of customer needs (if not 99) while ES required mostly for shops with huge SKU amounts, that's why there's no much progress in this module development.
Edited by DaoKakao
Hi DaoKakao, thank you for your help.
I can’t put elasticsearch 6.X working but with 5.4.0 it’s almost works.
My first problem if I installed correctly the elasticsearch?
Can you check if the how to elasticsearch cli raw installation that I put in the first post is ok, or I missed some steps?
