I have a problem with the display of customizations during checkout that happens both in the default theme and with Panda.
The normal display is this:
This looks ok. However, when you disable stockkeeping in the backoffice you get a problem. In that case in the first row the availability column disappears but in the second column the description keeps occupying three columns. That gives the following result:
musicmaster
Edited by musicmaster0 answers to this question
