smorjkompaniet Posted November 20, 2019 Posted November 20, 2019 I have upgraded to 1.1 stable from 1.08, but at the last step in checkout I get following error: Property Order->total_shipping is not valid in file classes/ObjectModel.php at line 1036 Source file: classes/ObjectModel.php 1017: * @throws PrestaShopException 1018: * 1019: * @since 1.0.0 1020: * @version 1.0.0 Initial version 1021: */ 1022: public function validateFields($die = true, $errorReturn = false) 1023: { 1024: foreach ($this->def['fields'] as $field => $data) { 1025: if (!empty($data['lang'])) { 1026: continue; 1027: } 1028: 1029: if (is_array($this->update_fields) && empty($this->update_fields[$field]) && isset($this->def['fields'][$field]['shop']) && $this->def['fields'][$field]['shop']) { 1030: continue; 1031: } 1032: 1033: $message = $this->validateField($field, $this->$field); 1034: if ($message !== true) { 1035: if ($die) { 1036: throw new PrestaShopException($message); 1037: } 1038: 1039: return $errorReturn ? $message : false; 1040: } 1041: } 1042: 1043: return true; 1044: } 1045: 1046: /** Stack trace 1. classes/ObjectModel.php:324 source ObjectModelCore->validateFields() 2. classes/order/Order.php:285 source ObjectModelCore->getFields() 3. classes/ObjectModel.php:586 source OrderCore->getFields() 4. classes/order/Order.php:303 source ObjectModelCore->add(arguments) 5. classes/module/PaymentModule.php:564 source OrderCore->add() 6. modules/custompayments/controllers/front/validation.php:116 source PaymentModuleCore->validateOrder(arguments) 7. classes/controller/Controller.php:197 source CustompaymentsvalidationModuleFrontController->postProcess() 8. classes/controller/FrontController.php:253 source ControllerCore->run() 9. classes/Dispatcher.php:837 source FrontControllerCore->run() 10. ./index.php:33 source DispatcherCore->dispatch() Anyone have a clue what it can be an what I can do about it? /Daniel
0 smorjkompaniet Posted November 21, 2019 Author Posted November 21, 2019 Hi, I seem to figure it out! The name on the carrier was to long(about 38 letters), I shored this down and everything work perfectly! Thank you for this wonderful shop and forum! /Daniel 2
smorjkompaniet
Stack trace
/Daniel
1 answer to this question
