Is there any idea how to fix the Block Layered Navigation order for filters ? When I create filter, I can put all available filters in order what I need, but this will not work. The same issue is from PS1.6, but after searching I couldn't get solution. Problem is that all filters are numbered (1, 2, 3 etc) and when You create this order then the result is something like this (21, 18, 8, 52 etc) This order is also presented in SQL database (_layered_filter, column name is "filters") but the result is anyway ordered bu numbers.
1 answer to this question
Looks like nobody cares. Partial fix (if this can be called fix) is to always put these filters in order before saving. When You open set of filters next time then this order is "not remembered" and after adding or deleting something you need to make this order again. Really annoying.
