Wartin Posted June 28, 2020 Posted June 28, 2020 I noticed that my products' description, after my test import, didn't have different lines, but just plain text all in one line. I use the data from SQL query where I select product's description. If I press 'view' button, the description shows something like: <div class="rte"> <p>adsf asd fasdfhal dsfash dfahsd fasjd</p> <p> </p> <p>asd</p> <p>f as</p> <p>df as</p> <p>df</p> <p>s</p> <p>long description</p> </div> If I export the same SQL command, resulting .sql file reads: adsf asd fasdfhal dsfash dfahsd fasjd^M ^M asd^M f as^M df as^M df^M s^M long description^M Obviously, when I use that .CSV file in an import, the description fields get broken. Maybe html is getting sanitized before exporting the CSV file? Thanks!
0 Wartin Posted June 29, 2020 Author Posted June 29, 2020 I didn't know what all these buttons in products do: Now I know the second is an export. Very nice. The last one add that query to SQL queries. I don't know what could be wrong, but the exported file using button number two is separated only by ; So when I open it in for example libreoffice all the rows appear one after the other, in one line. Any help will be appreciated.
Wartin
adsf asd fasdfhal dsfash dfahsd fasjd^M ^M asd^M f as^M df as^M df^M s^M long description^MObviously, when I use that .CSV file in an import, the description fields get broken.
Thanks!
1 answer to this question
