Mediacom87 Posted March 16, 2022 Posted March 16, 2022 Hello, Here is a complete redesign of an old module that incorporates some big changes. It will help you to display the QRCodes of your products with a simple click using an internal library independent of any third party service that you do not control. The module integrates a powerful caching system that does not impact the loading time of your pages, as well as the possibility to activate the native lazyloading to further improve the display performance. You will also be able to use QRCodes on your delivery notes to automatically change the status of the orders you are processing, thus saving a considerable amount of time on your order processing. The module also allows you to generate QRCodes for any web url or to contact you by email, phone, SMS or Skype. Basically it integrates everything that makes QRCode easy for your teams and your customers. Access to the demonstrations: https://qrcodepro.carrd.co/ Available on PrestaToolbox: https://www.prestatoolbox.com/front-office-features/285-google-qrcode-pro.html Available on Addons: https://addons.prestashop.com/en/mobile/6111-ultimate-qrcode-integration-on-your-store.html Available on thirtybees Marketplace: https://store.thirtybees.com/shop-modules/front-office/qr-code-pro
