Mediacom87 Posted April 10 Author Posted April 10 3.0.0 - 04/09/2024 On-demand scenario calculation shifted to avoid server overloads Calculation of the data counters to be cleaned is launched only on the scenarios selected for processing with a Cron task, enabling instant visualization of the volume of data to be cleaned without risk. Add a button to refresh the calculation only for scenarios programmed on a Cron task Added an option to change the database engine for InnoDB Add a SuperCron that can launch all Cron tasks with a single URL Add an option to mass uninstall all modules that have been deactivated Add a filter to display only modules by a specific creator Fixed cache issue when changing database table prefix for PrestaShop 1.6 DataTables library updated to version 2.0.3
Mediacom87 Posted April 23 Author Posted April 23 3.0.2 - 04/21/2024 Fixed bug preventing certain scenarios from being deleted from the catalog Fixed a bug in the option to uninstall several modules at the same time Improved feedback on certain scenarios that can take a long time Improved explanations to help with the use of certain scenarios DataTables library updated to version 2.0.5
Mediacom87 Posted May 10 Author Posted May 10 3.0.3 - 05/10/2024 Fixed a bug limiting the processing of certain scenarios Separation of scenarios to avoid data consistency bottlenecks DataTables library updated to version 2.0.7
Mediacom87 Posted May 13 Author Posted May 13 3.0.4 - 05/13/2024 Correction of Cron task management for new scenarios Add number of tables not using correct database engine
Mediacom87 Posted July 24 Author Posted July 24 3.0.5 - 07/23/2024 Complete code overhaul to clean up unnecessary product images Activate safe scenarios for crontask during module installation DataTables library updated to version 2.1.0 This is an important development, as it enables the analysis and cleaning of image folders containing millions of files. 1
Mediacom87 Posted August 14 Author Posted August 14 (edited) 3.1.0 - 08/01/2024 Correction of a display bug in the list of modules due to some modules having fun in their description Add preview of product images to be deleted Add an option to delete scenario files one by one concerning files not required for product images Add a scenario to automatically delete discount codes that have no date limit but can no longer be used DataTables library updated to version 2.1.3 Edited August 14 by Mediacom87
Mediacom87 Posted September 4 Author Posted September 4 3.1.1 - 09/04/2024 Fixed translation bug on tables Fixed processing incompatibility when using pm_advancedsearch4 module DataTables library updated to version 2.1.5
Mediacom87 Posted October 7 Author Posted October 7 3.1.2 - 10/07/2024 Added compatibility with the OpartDevis module to avoid deleting baskets linked to quotes. Fixed a bug in the display of some buttons DataTables library updated to version 2.1.8
Mediacom87 Posted November 14 Author Posted November 14 3.1.3 - 11/14/2024 Added compatibility with PrestaShop 9 Scenarios are calculated when the corresponding tab is displayed, to avoid overloading the server Improved module list display
Mediacom87 Posted November 19 Author Posted November 19 3.1.4 - 11/18/2024 Added compatibility with PHP 8.2
