rdw Posted October 24, 2022 Share Posted October 24, 2022 (edited) from error log.txtHello I've tried upgrading my test version to bleeding edge and I'm receiving the following error message when core update runs. All modules have been updated. Any help on this error would be grateful received. CoreUpdater\Api\ThirtybeesApiException: Server responded with error INVALID_REQUEST: Revision 1.3.0 not found in /home/abingdo2/xxxx.xxxxxx.org.uk/online_store/modules/coreupdater/classes/api/ThirtybeesApiGuzzle.php:378 Stack trace: #0 /home/abingdo2/xxxx.xxxxxx.org.uk/online_store/modules/coreupdater/classes/api/ThirtybeesApiGuzzle.php(319): CoreUpdater\Api\ThirtybeesApiGuzzle->unwrapResponse(Array, Object(GuzzleHttp\Psr7\Response)) #1 /home/abingdo2/xxxx.xxxxxx.org.uk/online_store/modules/coreupdater/classes/api/ThirtybeesApiGuzzle.php(133): CoreUpdater\Api\ThirtybeesApiGuzzle->callApi('8.1', 'list-revision', Array) #2 /home/abingdo2/xxxx.xxxxxx.org.uk/online_store/modules/coreupdater/classes/process/Comparator.php(448): CoreUpdater\Api\ThirtybeesApiGuzzle->downloadFileList('8.1', '1.3.0') #3 /home/abingdo2/xxxx.xxxxxx.org.uk/online_store/modules/coreupdater/classes/process/Comparator.php(296): CoreUpdater\Comparator->downloadFileList('8.1', '1.3.0', false, Object(CoreUpdater\Storage\StorageFilesystem)) #4 /home/abingdo2/xxxx.xxxxxx.org.uk/online_store/modules/coreupdater/classes/process/Process.php(98): CoreUpdater\Comparator->processStep('2088ad1c1fde3ed...', Array, Object(CoreUpdater\Storage\StorageFilesystem)) #5 /home/abingdo2/xxxx.xxxxxx.org.uk/online_store/modules/coreupdater/controllers/admin/AdminCoreUpdaterController.php(758): CoreUpdater\Process\Processor->process('2088ad1c1fde3ed...') #6 /home/abingdo2/xxxx.xxxxxx.org.uk/online_store/modules/coreupdater/controllers/admin/AdminCoreUpdaterController.php(733): AdminCoreUpdaterController->runProcess(Object(CoreUpdater\Comparator), '2088ad1c1fde3ed...', Object(Closure)) #7 /home/abingdo2/xxxx.xxxxxx.org.uk/online_store/modules/coreupdater/controllers/admin/AdminCoreUpdaterController.php(670): AdminCoreUpdaterController->compareProcess('2088ad1c1fde3ed...') #8 /home/abingdo2/xxxx.xxxxxx.org.uk/online_store/modules/coreupdater/controllers/admin/AdminCoreUpdaterController.php(647): AdminCoreUpdaterController->processAction('COMPARE') #9 /home/abingdo2/xxxx.xxxxxx.org.uk/online_store/modules/coreupdater/controllers/admin/AdminCoreUpdaterController.php(613): AdminCoreUpdaterController->ajaxProcess('COMPARE') #10 [internal function]: AdminCoreUpdaterController->performPostProcess() #11 /home/abingdo2/xxxx.xxxxxx.org.uk/online_store/modules/coreupdater/classes/ErrorHandler.php(70): call_user_func_array(Array, Array) #12 /home/abingdo2/xxxx.xxxxxx.org.uk/online_store/modules/coreupdater/controllers/admin/AdminCoreUpdaterController.php(599): CoreUpdater\ErrorHandler->handleErrors(Array) #13 /home/abingdo2/xxxx.xxxxxx.org.uk/online_store/classes/controller/Controller.php(204): AdminCoreUpdaterController->postProcess() #14 /home/abingdo2/xxxx.xxxxxx.org.uk/online_store/classes/Dispatcher.php(861): ControllerCore->run() #15 /home/abingdo2/xxxx.xxxxxx.org.uk/online_store/admin123/index.php(58): DispatcherCore->dispatch() #16 {main} Attached is a screen shot of my configuration screen Edited October 24, 2022 by rdw info from error attached Link to comment Share on other sites More sharing options...
0 e-com Posted October 25, 2022 Share Posted October 25, 2022 (edited) Change PHP to 7.4 Only after upgrading to TB 1.4.0 bleeding edge can you set PHP 8.1 And you should run Core Updater again. Edited October 25, 2022 by e-com 1 Link to comment Share on other sites More sharing options...
rdw
Stack trace:
#16 {main}
1 answer to this question
