I am looking at various options to fix/replace a TB 1.3 store that is not doing well.
One of the issues is that the main product has too many customizations so the traditional way of doing permutations is problematic as we quickly end up with a very large number.
With PS and then with TB I was able to avoid that issue by using a module called Advanced Attribute Wizard Pro that stored the permutations in a different manner.
With Presto Chango exiting the TB ecosystem I am looking for a module that either solves this issue with permutations becoming too large or that allows for conditional attributes which would likely be the better option.
If anyone knows of a module that could help me I'd appreciate being pointed in the correct direction.
