Victor Taza Posted September 16 Share Posted September 16 Hello! I am trying to hide the text that appears in red color and that indicates “Required Field” (especially I am interested in the one next to the proceed to payment button). Attached is a screenshot Link to comment Share on other sites More sharing options...
veganline Posted September 17 Share Posted September 17 (edited) Backoffice > Localisation > Translations > Front Office > Translations & Niara or whatever theme & English or Spanish > Modify Press "Expand all Fieldsets" If this was an unusual phrase, you could use Control+F to find it, but about 14 pages have it so you have to find something unusual on the same page to identify it. You could check how you set-up your order form and maybe guess from the names of the pages as well. If you can identify the page, change the translation from "Required Field" or "Campo Requirido" to "*" or "." Then try Backoffice > Advanced Preferences > Performance > Clear Cache. (There is a module that makes this work for Cloudflare as well I think) Check whether your change has worked, as it might be hard to find the exact page to change. Lastly, you have the problem of required fields that the customers do not know about. You could ask again on the forum! Changed translations should survive updates of the software. Hope this helps John PS if the text has unusual css round it, you can alter the css in backoffice > preferences > custom code > add css to your pages ... and add css to stop this unusual css showing. Probably not possible in this instance. Edited September 17 by veganline 1 Link to comment Share on other sites More sharing options...
