x97wehner Posted February 20, 2025 Posted February 20, 2025 Sharing this since I finally had time to look into the problem and figure out the issue of not all Stripe payment methods appearing on their hosted checkout page. If you're using the TB Stripe module, you likely noticed that with update to version 1.8 a while back, that you were no longer seeing all the payment methods you selected on your Stripe dashboard available in the hosted checkout page. This was a problem as we couldn't get Afterpay or Cash App to show up for customers to select. They are enabled on the Stripe dashboard, but not in the hosted checkout. Anyway, here is a band-aid fix until our TB dev's have time to properly adjust the module. You just need comment out a couple lines in the file StripeApi.php public function createCheckoutSession( Cart $cart, string $methodId, array $methods = [], array $paymentMethodOptions = [] ) { $context = Context::getContext(); $total = Utils::getCartTotal($cart); $validationLink = Utils::getValidationUrl($methodId); /* if (! $methods) { $methods = [ \Stripe\PaymentMethod::TYPE_CARD, ]; }*/ 1
