Martinfrade Posted 12 hours ago Posted 12 hours ago (edited) Hi, i'm a newbie with thirty bees. I have a problem when i'm editing the product descriptions fields, the editable field disappear from de form, and i can edit them, i shared a screenshot anybody had the same issue?? Any help ? Thanks in advance. the version is 1.6.0 Edited 12 hours ago by Martinfrade
yaniv14 Posted 10 hours ago Posted 10 hours ago my bet will be a bug introduced in this commit https://github.com/thirtybees/thirtybees/commit/9a30d95879bd76c9339c0dc9be3fa2855bfa0189 it seems like the codemiror plugin has no fallback for missing language file. can you check if this happens when you change admin user language to english? when I encouter similar error using Hebrew language i just made a copy from this file: js/tiny_mce/plugins/codemirror/langs/en.js to he.js and modified the lang prefix inside the file to 'he'.
Martinfrade Posted 9 hours ago Author Posted 9 hours ago I changed to english and the error continues. I checked the js/admin/tinymce.inc.js and i don't have any mention to codemirror and also in the plugin folder there isn't a folder named coremirror.
Martinfrade Posted 6 hours ago Author Posted 6 hours ago I tried to switch the language, log out, clean the cache, and after many tried the problem disappear suddenly, i don't know what happen but now the field are working fine.
