led24ee
Posts posted by led24ee
  1. I have TB 1.1 and niara theme. This box is visible only when I disable AEUC module. I haven't modified nothing. Unfortunately I'm not very skilled with codewriting. But something this AEUC moduel does. In AEUC template file (/.../modules/advancedeucompliance/views/templates/hook/hookOverrideTOSDisplay.tpl) there is "input checkbox" and everything looks like it must be working. This solution what is here (mars this cehckbox always check) is not really solution. I also download latest version from TB shop (there is remark, that last edit is done march 3/2021) but this doesn't change anything.
  2. 7 hours ago, yaniv14 said:
    This tutorial from 2017 most likely will work for you.
    I suggest (until proper fix will be implanted in core) doing some hack with javascript.
    That's why I suggest this (or some other solution) to be in next release. With javascript I have 0 experience. So I think I will do this to my shop and try to remember do it again after update.
  3. Well for this kind of delivery there is estimated cost. If product cost is about 2000 then there isn't really point is this delivery 110 or 140. At the moment I found that this is also not important so I can live without this. But I need to modify another module. I'm trying this almost 2 days, but still stuck. If anyone can help then I can give more details.
  4. Basically yes. This may sound stupid, but real problem is that I can't calculate transport price. Some items are too big for regular carrier. So if client order some items and I need to make them then I know only price for product. Transport price can calculate later and this can be done when actual delivery is in progress. Delay between product order and transport can be something like month.
  5. Now I have another problem. I need to add possibility that payment for transport can be done when products are delivered. Products will be sent when payment for products are done. Is there any suggestion how to add this option ? Or I need to search and install (or maybe modify something) some modules ?
  6. So the original problem is still not solved ? I mean this translation question. And this solution was to use another module ? Because I have the same problem. And payment name is module name. (This is on BO and on invoice too.) When You change module name in translations then this is also what You see on every place. I don't think it's good solution. So there is mistake and in some place the ID of translation what You need to use is wrong. Unfortunately I have no idea in which file this error is.
