toString method in Blowfish class to fix Cookie problem
Hello,
A few days ago I migrated a test clone of my website to thirtybees, I had some problems with my Blowfish and Cookie class when trying to acces the BO and FO.
Error :
PHP Recoverable fatal error:  Object of class Blowfish could not be converted to string in /home/shops/public_html/testclone/classes/Cookie.php on line 282
To resolve this error I created a toString method in both my Blowfish class and my CryptBlowfish class. It got rid of the errors and everything is working fine, but i'm wondering if this is a good solution.
Could anyone tell me if this is fine or if I could apply a diffrent fix?
2 answers to this question
  • 1
Sorry, that is not a best solution. It is just a cover-up of a bigger problem: there is something in your system that is trying to set Blowfish object inside your Cookie. There used to be a _cipherTool property inside Cookie class. This protected property used to hold cookie encryptor instance.
I bet you have some Cookie override that tries to set this (now not existing) property, which in turn causes the fatal error.
You can try this:
  1. revert your fix
  2. edit class Cookie.php
  3. at the very beginning, add this line:
protected $_cipherTool;
That should fix your problem. Anyway, this is a core compatibility issue, and it should be handled in the core.
  • Like 2
  • Thanks 1
