if by chance you install a module that isnt compatible..  an error occurs and when you click on the module list it returns the error..  how do "un-do" it...    asking for a friend.
error is:
Interface 'PrestaShop\PrestaShop\Core\Module\WidgetInterface' not found
the rest of the admin control panel works fine.
Edited by simon
its ok ,  I worked it out...  for my friend of course.
Solution: rename the folder of the last module uploaded then refresh.
sorry to bother.
