I recently tried several times to set up thirty bees as my websites e-commerce solution (I'm installing through Softaculous) but I get this error messageCapture.thumb.png.cf3688d828f049c150f03073682390a2.png
I tried googling it but I'm not all that great with this sort of thing so I couldn't follow any of what stack overflow suggested, I really want to use thirty bees but unless I can solve this I'll be stuck with a less functional and less visually appealing solution.
6 answers to this question
You might not like this answer, but I think the best thing to do would either be to contact your host or Softaculous. The reason being is that their software does not actually use our installer. What it does, is use their custom installer to import a database dump. So I am thinking the problem could be on their end. You can try to manually install thirty bees and see if you have an issue with it, then it would be something we can debug.
