Quant Posted April 22, 2019 Posted April 22, 2019 The productscategory module gives errors if you enable FullPageCache and disable caching for displayFooterProduct. [Mon Apr 22 18:26:22.209248 2019] [:error] [pid 25072] [client 127.0.0.1:53663] PHP Notice: Undefined index: product in /home/shop/www/modules/productscategory/productscategory.php on line 110, referer: http://tb.local/19-laki [Mon Apr 22 18:26:22.209278 2019] [:error] [pid 25072] [client 127.0.0.1:53663] PHP Notice: Trying to get property of non-object in /home/shop/www/modules/productscategory/productscategory.php on line 110, referer: http://tb.local/19-laki [Mon Apr 22 18:26:22.209294 2019] [:error] [pid 25072] [client 127.0.0.1:53663] PHP Notice: Undefined index: product in /home/shop/www/modules/productscategory/productscategory.php on line 111, referer: http://tb.local/19-laki [Mon Apr 22 18:26:22.209698 2019] [:error] [pid 25072] [client 127.0.0.1:53663] PHP Notice: Trying to get property of non-object in /home/shop/www/modules/productscategory/productscategory.php on line 113, referer: http://tb.local/19-laki Im use TB ver 1.0.8 (community theme) and php5.6. How to fix it?
0 wakabayashi Posted April 22, 2019 Posted April 22, 2019 I think, you shouldn't use FullPageCache for now. Btw: is there are reason for just using 5.6?
0 Quant Posted April 24, 2019 Author Posted April 24, 2019 The problem disappears if you update the TB via CoreUpdater. Then the errors disappear.Ps. I use php5.6, only for the test, while I transfer PS1.6.1.23 to TB.
Quant
How to fix it?
2 answers to this question
