hi there i'm new to bhirtybees i come from prestashop
how can i add some custom css without losing it during upgrade?
i need to edit some cssinfo module and i don't want do loose it during upgrade
is there any way to do it?
There is a section under preferences called custom code, you can add your custom css there and it will be saved through upgrades of the core and modules.
