Gudron11 Posted August 14, 2019 Posted August 14, 2019 I have just installed the TB 1.1.0 and making a store on it. I faced the following problem - most files are not loading. The button Upload is not working in Image upload, CSV import and loading attachment files. In module Blog form of adding images works correctly. Hosting is good enought, several PS 1.6 and 1.7 projects are working fine there.
0 Traumflug Posted August 16, 2019 Posted August 16, 2019 Could you elaborate a bit more on what exactly you try to do? There are certainly a dozen places where one can upload an image. Are you trying to upload products by importing a CSV with image links inside? Which error messages do you get? For debugging it's a good idea to try with a CSV file with just 2 or 3 lines inside. Once 2 lines work, 2000 lines are no problem.
Gudron11
1 answer to this question
