Hi guys. I am a newbie with absolutely no programming skills. I've been trying to install Thirty Bees using Softaculous and shared hosting by Namecheap. After what seems to be a successful installation, I keep getting an HTTP Error 500 when i navigate to my domain. Any help to get past this is appreciated.
Edited by ellosbaby
Dont know how up-to-date this is, but does your site meet the minimum requirements?
Requirements
Support for these general requirements (except recommendations) gets tested during installation, so one can simply try to proceed. A proceeding installation means all requirements are met.
  • PHP 5.6 - PHP 7.3 with a minimum of 128 MiB RAM
  • Apache or nginx
  • Linux or MacOS
  • MySQL 5.5.3+ or MariaDB 5.5+
  • PHP extensions:
    • Required:
      • bcmath
      • gd
      • json
      • mbstring
      • openssl
      • mysql (PDO only)
      • xml (SimpleXML, DOMDocument)
      • zip
    • Recommended:
      • imap (for allowing to use an IMAP server rather than PHP's built-in mail function)
      • curl (for better handling of background HTTPS requests)
      • opcache (not mandatory because some hosters turn this off in favor of other caching mechanisms)
      • apcu/redis/memcache(d) (for the (currently incomplete) full page cache)
Thanks.
Softaculous Support resolved this for me. Here's the explanation:
"thirty bees need an encryption key, Softaculous generate that key by CURL call.
For some reason curl call failed and that issue occurred."
