Just discovered that 25,000 products were no longer indexed after migration.  Running search cured this but if you migrate to TB make sure you run search to re-index products.  Good idea to run prestashop cleaner Check and fix before migrating.
Then run the TB cleaner check and fix before jumping to TB 1.1.  Had much greater success where the theme came through without losing pictures.
Edited by Joint Systems
correction
