Sendcloud module
Sendcloud have just started in the UK today and I was planning to give them a try. Unfortunately the download link on the Thirtybees modules store is broken and I can't get the zip from Github to install - It says module is "successfully downloaded" in module admin however it doesn't appear.
Has anyone got a solution?
2 answers to this question
The zip file from their git repository is not a valid module zip archive. You need to extract it, and manually copy directory sendcloud from the archive to your modules directory (using ftp). Then you can install it normally
