Hello, My site is not showing now after moving it from hostgator to ionos on a vps L server with plesk. I am getting this message from the database:
Link to database cannot be established: SQLSTATE[HY000] [1045] Access denied for user 'erbornb2_thbee19'@'localhost' (using password: YES)
I found a fix or so I thought it was a fix to go to the config/settings.inc.php so I changed the password to the new one I put in the maria database. (just a note the old data base was not a maria could that be the problem?)
Thank you
Ron
