Hi!
The shop today connect to a local msql server. But we want to change that and connect to a remote one. I have donee all preparations and the user is approved and tested. But how should it look in settings.inc?
_DB_SERVER_', 'localhost');
define('_DB_NAME_', 'db_jv74');
define('_DB_USER_', 'jxxxx');
define('_DB_PASSWD_', 'xxxxxxxx');
Well our mysql server do that. It only has to do with the bind address. And as said I have already tested the user from remote, the question is if just the username is enoughj because when you test it you use user@ip
