AndyC Posted October 1, 2022 Posted October 1, 2022 (edited) After years of searching for a better module than the 1 I am using at the moment, I have found the perfect module for my needs. I was wondering does anyone use this module at all and preferably with Panda and how does it perform. It also may benefit other users as this module looks very good for the price as you can up-sell stuff easily https://addons.prestashop.com/en/combinaisons-customization/88078-custom-product-options-add-extra-fields-to-product.html#overview The main reason I need to change is because the module I use now doesn't add up correctly at checkout and payment modules have to be modded to be able to work properly + other minor things that have had changes made Thanks Edited October 1, 2022 by AndyC
AndyC Posted November 25, 2022 Author Posted November 25, 2022 Does anyone use anything like this, really would like to know as I don't want to waste even more money on a module that fails with TB 1
Obi Posted August 5, 2025 Posted August 5, 2025 On 11/25/2022 at 10:43 AM, AndyC said: Does anyone use anything like this, really would like to know as I don't want to waste even more money on a module that fails with TB A few years later, in case anyone stumbles onto this post... This does not support TB. The module is written for PS 1.7.0 thru 9.0 and it uses overrides, which in itself is not necessarily a bad thing, but if you have other overrides, you might have to dig into some code to make it all work together. I'm still looking for a better product combinations method (or online designer) for custom branded softgoods and hardgoods.
