Marta Posted December 17, 2022 Posted December 17, 2022 Hello, as my shop is far slower than a toaster I've decided to install it from scratch. I'm importing tables at the moment and I've got problems with tb_product_attribute. I am getting the following error: INSERT INTO `tb_product_attribute` VALUES ('76', '451', '67250', '', '0', '5905001672506', '', '0.000000', '114.950000', '0.000000', '0', '0.000000', '0.000000', '0', '1', '0000-00-00'); Quote MySQL zwrócił komunikat: #1062 - Duplicate entry '451-0' for key 'product_default' There are 5 attributes for this id_product and only one of them is set to 1 in the default_on field. MySQL imports only two of them. 😞 Is everything all right with the table configuration?
0 musicmaster Posted December 17, 2022 Posted December 17, 2022 It looks like you are crossing the PS 1.6.0-1.6.1 barrier. In 1.6.0 the default has value 1 and the other value 0. In 1.6.1 (and TB) the NULL value is used instead of 0. That enables the system to make the field a unique key - what makes it imposible to have more than one default. NULLs are excepted from this unique requirement. However, zeroes do trigger duplicate key errors. You are likely to experience similar problems with pictures. 1
Marta
There are 5 attributes for this id_product and only one of them is set to 1 in the default_on field.MySQL imports only two of them. 😞Is everything all right with the table configuration?1 answer to this question
