If you want to import product supplier information, and if you are on tb1.5, you can use my free module
https://store.getdatakick.com/en/free-stuff/import-product-supplier
This module does not perform the import itself. It simply registers new CSV import entity Product Supplier.
Standard thirty bees CSV Import will see this entity type and can work with it.
New version of the module also supports two new fields Supplier Product Name and Additional comments.
