Kevin13952 Posted December 20, 2023 Posted December 20, 2023 I try to create a new product in back office. Everything saves fine except for the product quantity. I enter 5 in quantity available and click "Save and Stay" and the available quantity resets to zero. In Front Office it shows the item as out of stock. How do I fix this so it saves the available quantity? I'm NOT using advanced inventory management. Just the default basic inventory.
0 nickz Posted December 20, 2023 Posted December 20, 2023 7 hours ago, Kevin13952 said: I try to create a new product in back office. Everything saves fine except for the product quantity. since when does that happen? In which shop version, theme and all the rest what could be part of the scenario.
0 SLiCK_303 Posted December 22, 2023 Posted December 22, 2023 (edited) I find if you set the quantity you want, then simply click on the page, like to the right of the quantity block, it will bring up a pop-up saying it saved. Edited December 22, 2023 by SLiCK_303
Kevin13952
2 answers to this question
