I found a Bug in the Advanced Stock Management when you try to transfer not-usable products.
You can recreate this, if you do the following steps:
* The Stock of WarhouseA is empty (Physical and usable)
* Add Products to WarehouseA and set the "usable for sale" to false/no
* Now use Transferstock in the Action-List of WarehouseA
* set a quantity to transfer
* Select usable in source to false/no (there is no usable Stock, so you want to move the physical)
* Select WarhouseB as the destination
* Finaly you select usable for destination to true/yes
* click on transfer
-> you will end up with this error:
"It is not possible to transfer the specified quantity. No stock was transferred. "
i found the line where i think it goes wrong in classes/stock/StockManager.php
in Line 602:
public function getPhysicalProductQuantities($productStockCriteria)
isset($productStockCriteria['usable']) ? : false
this changes the submitted "usable_from" from false to true because the variable exists (with a value of "false") and therefore isset will return true.
This could be fixed in a simple way:
isset($productStockCriteria['usable']) ? $productStockCriteria['usable'] : false
Now the statement not only checks, if 'usable' exists, it also uses the value of it and defaults to false, if it's missing.
CHitzmann
I found a Bug in the Advanced Stock Management when you try to transfer not-usable products. You can recreate this, if you do the following steps: * The Stock of WarhouseA is empty (Physical and usable) * Add Products to WarehouseA and set the "usable for sale" to false/no * Now use Transferstock in the Action-List of WarehouseA * set a quantity to transfer * Select usable in source to false/no (there is no usable Stock, so you want to move the physical) * Select WarhouseB as the destination * Finaly you select usable for destination to true/yes * click on transfer -> you will end up with this error: "It is not possible to transfer the specified quantity. No stock was transferred. "
i found the line where i think it goes wrong in classes/stock/StockManager.php in Line 602:
public function getPhysicalProductQuantities($productStockCriteria) { ... isset($productStockCriteria['usable']) ? : false ... }
public function getPhysicalProductQuantities($productStockCriteria) { ... isset($productStockCriteria['usable']) ? $productStockCriteria['usable'] : false ... }
Now the statement not only checks, if 'usable' exists, it also uses the value of it and defaults to false, if it's missing.Link to comment
5 answers to this question
