I just installed1.0.4 for testing and it is working fine so far.
Just found couple of minor bugs. And I will continue testing these days with adding carriers, test orders, etc.
There is webp images option in preferences/images. It should be removed when it is not available.
The high res images don’t show on apple devices and I don’t think they are loading on my pc either. I know they may be not working, but I’t could be something easy to fix…
Which image is exactly loading here? :
It's from the new arrivals carousel on the homepage.
When I open the third link for example, I see it is loading image with resolution 250x250 which is set in back office images for home_default, but the loaded x2 image should be with resolution 500x500. It is replacing the name of the image with the alt image name, and I can’t see which one is loaded, but there is x2 at the end as it should…
MockoB
I just installed1.0.4 for testing and it is working fine so far. Just found couple of minor bugs. And I will continue testing these days with adding carriers, test orders, etc.
19 answers to this question
