Hi, there: I have the following problem attached:
Warning: require(/var/www/vhosts/----------------/httpdocs/BEES104/vendor/composer/../symfony/polyfill-mbstring/bootstrap.php): failed to open stream: No such file or directory in /var/www/vhosts/-------------------/httpdocs/BEES104/vendor/composer/autoload_real.php on line 70
Warning: require(/var/www/vhosts/--------------/httpdocs/BEES104/vendor/composer/../symfony/polyfill-mbstring/bootstrap.php): failed to open stream: No such file or directory in /var/www/vhosts/------------------/httpdocs/BEES104/vendor/composer/autoload_real.php on line 70
Fatal error: require(): Failed opening required '/var/www/vhosts/------------------------/httpdocs/BEES104/vendor/composer/../symfony/polyfill-mbstring/bootstrap.php' (includepath='/var/www/vhosts/---------------/httpdocs/BEES104/vendor/pear/pearexception:/var/www/vhosts/------------------/httpdocs/BEES104/vendor/pear/consolegetopt:/var/www/vhosts/-------/httpdocs/BEES104/vendor/pear/pear-core-minimal/src:/var/www/vhosts/----------------/httpdocs/BEES104/vendor/pear/archivetar:.:/opt/plesk/php/7.1/share/pear') in /var/www/vhosts/-------------------------/httpdocs/BEES104/vendor/composer/autoload_real.php on line 70
That only appears in the firefox browser and I have no idea what it means.
9 answers to this question
Thanks for your attention, I really don't know what the problem is, I have disabled all debug modes in /config/ and in the back office I have disabled all the modules I have installed I have only left the main installation and not all of them. and the problem keeps coming up, I've been using prestashop for many years since 1.4 and I don't think this has ever happened to me before.
I also tried to change my php to 7.1 and lowered it to 7.1.
The website is: https://expomueble.es
I thought it was only in firefox but you also see the error in chrome after deleting the history.
This part isn't much of a surprise. PHP code runs in the server, not in the browser.
What bugs me a bit: the error message asks for a Symphony file, which shouldn't be part of the thirty bees distribution. Do you happen to run not an unpacked ZIP file, but a Git clone? In the latter case, did you run composer install ?
Thank you very much for your attention, because this is really strange, because the web was really working well but I don't know what happened that overnight it doesn't work at all. I'm not saying it's from the thrirtybees code.
I'm just asking for help to see if I don't lose all the work I've done.
As I'm not an expert programmer, I don't understand what you mean, what happened is that as it didn't work well I recovered a backup from two days ago and installed it again including the database, but it still doesn't work.
Right now I don't remember if there was an update of plesk and/or some module of thirtybees too.
After breaking my head for a few days I have come to the conclusion that the problem was Ningx, surely in the last update of plesk they have included a ningx update and it has brought me upside down, until I have changed to apache the problems have not been solved.
If anyone can help you.
On some other forum(s) there were people facing same problems. The root of problem in some case was the hosting setting(s).
I can say, the 100% workin solutions are: a) select official 30bees cloud partner, and deploy your shop on their facilities, b) use VPS or dedicated server. In any case, any kind of serious web-shop requires valuable amount of server resources, it is always bad idea to deploy your shop on the cheapest hosting plan(s).
