Cassim Posted July 11, 2018 Posted July 11, 2018 Hallo their. Version 1.5 My Mailchimp returns this message, when i try to connect to the site. ""MailChimp webhooks kunne ikke implementeres. Prøv venligst igen. "" In english "" Mailchimp webhooks can't be implementet please try again "" Also i don't send revenue over in Mailchimp. Why is that. ?
x97wehner Posted July 11, 2018 Posted July 11, 2018 I had some issues here as well. I had to create a new API in Mailchimp. Disable the old API. Then in the thirtybees module, I added the new API, added the tax choice, and synced the shop. Then it finally connected. I was able to do a full sync of orders, carts, products, etc right afterward. Still working on getting the CRON jobs running correctly though. Check this blog for some of the details. It's missing some info for us non-developer folks though. https://thirtybees.com/native-modules/new-module-mailchimp/
Cassim Posted July 16, 2018 Author Posted July 16, 2018 @x97wehner said in Mailchimp webhook not able: I had some issues here as well. I had to create a new API in Mailchimp. Disable the old API. Then in the thirtybees module, I added the new API, added the tax choice, and synced the shop. Then it finally connected. I was able to do a full sync of orders, carts, products, etc right afterward. Still working on getting the CRON jobs running correctly though. Check this blog for some of the details. It's missing some info for us non-developer folks though. https://thirtybees.com/native-modules/new-module-mailchimp/ Thanks This did work for me. But still no revenue in my Mailchimp. :(
