teleservicecenter Posted August 24, 2018 Share Posted August 24, 2018 So, we have this product, "Aanmaken of configureren account", this is marked as visible nowhere. In catalog or search the product really isn't visible, but the block cross selling product does show this product in frontend. The product configuration: Block Cross Selling: Link to comment Share on other sites More sharing options...
0 doclucas Posted September 14, 2018 Share Posted September 14, 2018 To fix this, open /modules/crossselling/crossselling.php Change: AND product_shop.active = 1 '.(Group::isFeatureActive() ? $sql_groups_where : '').' To: AND product_shop.active = 1 AND p.visibility IN ("both", "catalog") '.(Group::isFeatureActive() ? $sql_groups_where : '').' Make sure you clear cache in the BO performance page, then test. Hope this helps. :) Link to comment Share on other sites More sharing options...
0 doclucas Posted September 14, 2018 Share Posted September 14, 2018 GitHub pull request: https://github.com/thirtybees/crossselling/pull/1 Link to comment Share on other sites More sharing options...
teleservicecenter
The product configuration:![0_1535096185962_303fa570-6fde-4774-88c1-bd6eb7d16954-image.png](//forum.thirtybees.com/applications/core/interface/js/spacer.png)
Block Cross Selling:![0_1535096094807_e563b08c-e7bc-497d-a824-e4eeb7bcb78b-image.png](//forum.thirtybees.com/applications/core/interface/js/spacer.png)
2 answers to this question
