Save when changing products
Every time I change a product, for example the quantity, a red error appears in the upper right corner. But he just stores everything. So if I have changed something, it has also been implemented.
There is nothing in the error. Only error.
I use 1.0.7
10 answers to this question
I think I've found (and fixed) this. It's a harmless error message, one can safely ignore it.
https://github.com/thirtybees/thirtybees/commit/3774d272bdc629c30e689b47eaf434e86da2ffa6
@peter said in Save when changing products:
Every time I change a product, for example the quantity, a red error appears in the upper right corner. But he just stores everything. So if I have changed something, it has also been implemented. There is nothing in the error. Only error. I use 1.0.7
Hi, I had the same problem. Dear friend
@vanaklaser said in Save when changing products:
@Traumflug posted the solution a phew posts above :)
How can i change it to solved?
The grey button, Topic Tools under the first post and at the bottom of each thread. It's actually a menu and there's Mark as solved inside. The green menu item.
@traumflug said in Save when changing products:
Are you a moderator at this forum? Because can't see it.
