In a B2B store, we are using round each item, 2 decimal, and we set all products with price excluded taxes.
Some customers has a group discount (ie, 5%)
Tax calculation is wrong, probably it doesn't round the product price before calculating the tax amount.
In example, 22% of 12.1753 is = 14.8538 but when using 2 decimal, 22% of 12.18 is 14.8596 that is 14.86.
This is 1 cent more. If you have multiple items in the cart, in example, a product with 48 or 56 bottles, you have some euros less.
This is the same in PS 1.6 to 1.7.2, there are some long-date opened bugs with no fix (they are focused to some "higher priority" tasks than fixing the tax calculation O_o )
Probably , PS/TB internally are using the number without rounding (so, with 4 decimal precision) because in psorderdetail I can the product stored with 4 decimals, in example, we have a product (real "correct" price is 4.85) stored as "4.845000" in psorderdetails.
Customer bought 6 of this, thus real total price should be 4.85*6 = 29.10 but PS/TB is calculating it as 29.07
In backoffice I can see the correct price (29.10) but the total tax calculation for the whole cart is wrong, as it is calculated based on 29.07
gandalf
In a B2B store, we are using round each item, 2 decimal, and we set all products with price excluded taxes. Some customers has a group discount (ie, 5%)
Tax calculation is wrong, probably it doesn't round the product price before calculating the tax amount. In example, 22% of 12.1753 is = 14.8538 but when using 2 decimal, 22% of 12.18 is 14.8596 that is 14.86. This is 1 cent more. If you have multiple items in the cart, in example, a product with 48 or 56 bottles, you have some euros less.
Customer bought 6 of this, thus real total price should be 4.85*6 = 29.10 but PS/TB is calculating it as 29.07 In backoffice I can see the correct price (29.10) but the total tax calculation for the whole cart is wrong, as it is calculated based on 29.07
9 answers to this question
