musicmaster Posted March 18, 2019 Posted March 18, 2019 I am using the Panda theme. I can switch on the high resolution images. But it looks like I can never switch them off again. I put "Generate High resolution images" to no. I delete the "2x" image formats. But nothing makes a difference: the website keeps producing links like <img class="replace-2x img-responsive front-image " src="http://localhost/8377-home_default_2x/balla.jpg" alt="Balla" title="Balla" width="293" height="293" itemprop="image"> This means I have two problems: - I cannot disable high res images - when it serves high res images it serves them always - even when low res would be recommended. Does anyone have solutions for these problems?
Jonny Posted March 18, 2019 Posted March 18, 2019 Disable the "Retina" setting in the Theme editor module.
musicmaster Posted March 25, 2019 Author Posted March 25, 2019 On 3/18/2019 at 3:31 PM, Jonny said: Disable the "Retina" setting in the Theme editor module. That does not work.
musicmaster Posted March 25, 2019 Author Posted March 25, 2019 1 hour ago, musicmaster said: That does not work. I found it was some thing else. Problem solved. 1
