felipeseo Posted May 28, 2019 Posted May 28, 2019 Hello, does anyone know why this happens to me? and that is that when I save the translations it takes me out of the administrator also when I re-enter the texts are red https://www.screencast.com/t/PSPciVW1kjZ1 and the translation is not seen in the front
0 musicmaster Posted May 28, 2019 Posted May 28, 2019 A redirect to the home might be caused by some bug in an url: either an extra space, a variable indicating the path that was not set or some javascript error. Did you clean your TB cache and the browsercache?
0 felipeseo Posted May 28, 2019 Author Posted May 28, 2019 (edited) I think I've seen the error and that is when I save save and stay, redirect me to https, when I'm working on http. I am working on a parallel folder of a site that has https. How I can avoid this? Edited May 28, 2019 by felipeseo
0 felipeseo Posted May 28, 2019 Author Posted May 28, 2019 I think it was not the error because I activated the https for this provisional site and it does not work I keep on with the same error, it redicts me to the main domain site when it spikes in saving
0 musicmaster Posted May 28, 2019 Posted May 28, 2019 Deleting cookies is not the same as deleting the cache. If the main site is another site then somewhere you must have mentioned that main url. Otherwise it couldn't find it.
0 felipeseo Posted May 28, 2019 Author Posted May 28, 2019 (edited) already delete the cache and follow the same problem, Edited May 28, 2019 by felipeseo
0 yaniv14 Posted May 28, 2019 Posted May 28, 2019 This probably happens because of server security. Turn off mod_security module on your server and if its still not working ask your server hosting company to check the specific url
0 felipeseo Posted May 28, 2019 Author Posted May 28, 2019 I think you may be right, because when I make this change the site is recognizing me as spam and a recaptcha appears, so I think it's time for me to wait until I can work in the main url
felipeseo
7 answers to this question
