All:
I looked around and can't find anything.  I want to add pages to the site.  I found the cms part.  I can create a page there.  How can I transplant modules on to this new page.  Do I need to put it on SEO and urls as well?
Example I want to duplicate the Manufacturers page and only show some items they sell.
How best to do this?
8 answers to this question
I believe there is no easy solution for this. You could code a new FrontController.
As this is kind of normal idea, it should be easier IMHO. Thats why I am a big fan of the shortcode idea. I am not sure, if there is a good shortcode module available (I use my own stuff).
Teach me and I will.  Any visual recommendations on learning or courses.  Keep in mind I am old...  I actually know where DOS came from and what DCL is..LOL
normal idea
Right it needs to be like widgets.  Create page > transplate module AKA widget > add custom content = new page.
I use my own stuff
your picture shows a sharing kind of guy... 🙂
Right now I can not share this, cause my shortcode stuff is inbuilt in my blog module (which is a paid one).
What do you wanna achieve exactly? Cause a manufacturer page (product listing) is quite different from a cms page (html text)...
No worries..  I know if you could you would.
in general. I want the manufacture page to look more like a category page.  I want an image at the top that is like a category image. With the manufacturers images below.  I have the panda theme. I am still learning all it can do.. it maybe able too.
Actually more like this one https://www.spielezar.ch/marken
But where your Grey area is I want a image banner.  Also where is the part that makes it go horizontal or like a grid? like yours?
Like this...  https://www.missouriquiltco.com/shop/fabric-yardage-by-brand . it's not prestashop
ok if I change the TPL files.  Won't that go away in a upgrade? I guess I need to make a separate tpl file and do an include?
