Signut Posted July 21, 2019 Posted July 21, 2019 In Order to use the VAT Exemption Module do we have to roll back from 1.0.8 Bleeding Edge to TB 1.0.8? Could there be other reasons the Vat Exemption Module is 'not compliant' ? Grateful for any advice, thanks.
Traumflug Posted July 21, 2019 Posted July 21, 2019 That's probably a Yes. Changing _TB_VERSION_ in config/settings.inc.php should be sufficient. It can get restored after the installation.
Signut Posted July 21, 2019 Author Posted July 21, 2019 Thank you @Traumflug, Changing the TB_Version worked.😀 1
Traumflug Posted July 22, 2019 Posted July 22, 2019 Let's not forget this: https://github.com/thirtybees/thirtybees/issues/998
