Chris1d Posted October 6, 2019 Posted October 6, 2019 My cart stopped working during testing so I reset the module, which has fixed the issue but now the basket "my cart" icon is sitting under the blocktopmenu instead of up in the top right corner where it was. I'm using the default theme...how do I fix this? Thanks!
yaniv14 Posted October 6, 2019 Posted October 6, 2019 Go to modules -> positions and play with the block cart position (up or down) inside displayTop section
SLiCK_303 Posted October 6, 2019 Posted October 6, 2019 (edited) edit: didnt see @yaniv14 post b4 i posted....we said the same thing, it's a position issue hopefully. I would guess it's just a position issue. Goto BO>Modules & Services>Positions look for displayTop, make sure your's looks like this ... Edited October 6, 2019 by SLiCK_303
Chris1d Posted October 6, 2019 Author Posted October 6, 2019 The only place I didn't look! Thank you so much! All fixed! 1
