Using 1.1.x BE as of this writing, when you export a theme, any theme I imagine, but I used niara as an example, the hooks for modules often get duplicated. This is my config.xml file the system just created, and if you goto the hook info, on some modules, especially 3rd party modules, but also on tb modules, you will see this.
SLiCK_303
config.xml
5 answers to this question
